Methods
Menus
(version: 2.11)
File
- Open
- Save
- Global Shift settings
- Primitive factory
- 3D mouse > Enable
- Gamepad > Enable
Edit
- Clone
- Merge
- Subsample
- Apply transformation
- Multiply/Scale
- Translate/Rotate
- Segment
- Crop
- Edit global shift and scale
- Toggle (recursive) submenu
Colors
- Set unique
- From Scalar fields
- Colorize
- Levels
- Height ramp
- Convert to grey scale
- Convert to scalar field
- Enhance with intensities
- Compute
- Invert
- Convert to > HSV colors
- Export normals to SF(s)
Octree
Grid
- Delaunay 2.5D (XY plane)
- Mesh scan grids
- Sample points
- Smooth (Laplacian)
- Subdivide
- Flip triangles
- Measure surface
- Measure volume
- Flag vertices by type
Mesh \ Scalar field
Polyline
Plane
Sensors
Sensors \ Other
Scalar fields
- Show histogram
- Compute stat. params
- Gradient
- Gaussian filter
- Bilateral filter
- Filter by Value
- Convert to RGB
- Convert to random RGB
- Rename
- Add constant SF
- Add point indexes as SF
- Set SF as coordinate(s)
- Arithmetic
- Color Scales Manager
- Delete
Waveform
Tools
Clean
Projection
- Unroll
Registration
- Match bounding-box centers
- Match scales
- Align (point pairs picking)
- Fine registration (ICP)
Distances
Volume
Statistics
Segmentation
Fit
Batch export
Other
- Density (v2.9)
- Curvature (v2.9)
- Roughness (v2.9)
- Remove duplicate points
Display
- Full screen
- Full screen (3D view)
- Refresh
- Toggle Centered Perspective
- Show cursor coordinates
- Enter bubble-view mode
- Camera link
- Render to File
- Display options
- Camera settings
- Save viewport as object
- Adjust zoom
- Test Frame Rate
Lights
Shaders & Filters
- Remove filter
Active scalar field
Other
Plugins
3D Views
- New
- Close
- Close All
- Tile
- Cascade
- Next
- Previous
