Cross Section
Additionally, this tool can:
Editing the clipping box
Interactively
Numerically
Visualization
Extract a single slice
Extract a single envelope
Additional options are:
Extracted envelope (close-up with the slice cloud)
Extract contours inside a single slice
Extracted contours
Extract multiple slices, envelopes or contours
Other parameters are:
Multiple slices (left) and envelopes (right) extraction
Reset the clipping box
Close the tool
