Toolbars and icons
Icons in each toolbar are described from left to right.
All toolbars are dockable elements that can be freely displaced, docked or let floating over the application window.
Main toolbar
Open
Save
Point Picking (point, segment, triangle or 2D area picking)
Point list picking (list of picked points exportable to a new cloud, polyline or file)
Clone
Merge
Delete (selected entities)
Align (point pairs picking)
Fine registration (ICP)
Subsample (cloud)
Sample points on a mesh
Cloud-to-Cloud distances computation
Cloud-to-Mesh distances computation
Connected components extraction
Primitive factory
Rasterize tool
Interactive segmentation tool
Interactive transformation tool
Cross Section tool
Sections extraction tool
Scalar fields toolbar
Show the histogram of the active scalar field
Compute the statistical parameters of the active scalar field
Filter the points based on their associated scalar value
Deletes the active scalar field of the selected entities
Perform arithmetic operations or apply standard functions on one (or two) scalar fields
Color Scales Manager
OpenGL filters (shaders) toolbar
The content of this toolbar depends on the detected/supported "shaders" plugins that have been successfully loaded at startup.
- Remove active OpenGL filter
- Blur (simple screen blurring - for demo)
- E.D.L. (Eye Dome Lighting)
- S.S.A.O. (Screen Space Ambient Occlusion)
Standard plugins toolbar
The content of this toolbar depends on the detected/supported plugins that have been successfully loaded at startup.
- additional toolbars can be added by plugins with multiple methods (e.g. qPCL, qSRA, qCANUPO, etc.)
- see the plugins list
3D view toolbar
Display settings (lights, materials, colors, etc.)
Camera settings (active 3D view)
Full scene zoom (active 3D view)
Pick a point as rotation center (active 3D view) - works also on meshes/triangles
Automatically pick a point as rotation center in the middle of the screen (active 3D view) - works also on meshes/triangles
Select projection mode (orthographic / perspective)
Set rotation symbol visibility
Zoom (and center) on selected entities
Set camera to top view
Set camera to front view
Set camera to left view
Set camera to back view
Set camera to right view
Set camera to bottom view
Set camera to iso view (front)
Set camera to iso view (back)
Enable stereo (anaglyph) mode
Note: this toolbar is situated on the left side by default.
