Shortcuts
Revision as of 15:47, 7 March 2021 by Daniel (talk | contribs)
Here are listed the keyboard shortcuts (version: 2.12)
Shortcut Description
Ctrl + O Open file
Ctrl + S Save selected entities
Ctrl + P Create a point cloud from the contents of the clipboard (text/ASCII)
Ctrl + T Starts the Apply transformation tool
Ctrl + V Creates a 2D viewport object (to save the current 3D view parameters and camera position see)
Alt + C Set unique color (selected entities)
Del/Suppr Delete selected entities
A Toggle selected entities activation
B Enter bubble-view mode
C Toggle selected entities colors visibility (recursive)
D Toggle selected entities 3D name visibility (recursive)
E Export the selected clouds information
L Lock manual rotation around the vertical (screen) axis
M Toggle selected entities materials/textures visibility (recursive)
N Toggle selected entities normals visibility (recursive)
P Picks the rotation center (active 3D view)
S Toggle selected entities SF visibility (recursive)
T Starts the Interactive Segmentation (scissors) tool
V Toggle selected entities visibility (recursive)
X Starts the cross section tool
Z Zoom and center view on selected entities
double-click Sets the clicked pixel as rotation center (active 3D view)
Shift + left mouse click on a point/triangle Spawns a 2D label on the picked point / triangle
Shift + C Toggle selected entity color ramp visibility (recursive)
Shift + Up arrow Activate previous scalar field on selected entity
Shift + Down arrow Activate next scalar field on selected entity
F1 Show help
F2 Rename selected entity (in DB tree)
F3 Toggle object-centered perspective (active 3D view)
F4 Toggle viewer-based perspective (active 3D view)
F5 Refresh display (active 3D view)
F6 Toggle sun light (active 3D view)
F7 Toggle custom light (active 3D view)
F8 Toggle Console display
F9 Toggle application full-screen mode
F10 Toggle stereo mode
F11 Toggle 3D view full-screen mode
Ctrl + F3 New 3D view
Ctrl + F4 Close active 3D view
0 Set default "BACK" view to active 3D display
2 Set default "BOTTOM" view to active 3D display
4 Set default "LEFT SIDE" view to active 3D display
5 Set default "FRONT" view to active 3D display
6 Set default "RIGHT SIDE" view to active 3D display
8 Set default "TOP" view to active 3D display
+ Increase the zoom of the active 3D display (since version 2.6.2)
= Decrease the zoom of the active 3D display (since version 2.6.2)
Ctrl + mouse wheel Change the default point size
Alt + mouse wheel Change the near clipping plane (perspective mode)
Shift + mouse wheel Change the field of view (perspective mode)
Shift + P Toggle the 'Auto-pick center' option on the active 3D view
