ICP differences between using point cloud and STL
DanceEng
Post by DanceEng »
Hi all,
Can there be a difference between using a mesh vs using a point cloud (scanned surface) when using the ICP register feature? I assume it is the same with the caveat that points may be sampled from the mesh(s) to do the calculations.
Re: ICP differences between using point cloud and STL
Yes, it's all about how the points are sampled. It will be probably more regular with a mesh (otherwise with a point cloud only a random number of points is chosen at each iteration).
