Exporting the 3D-Models in Web formats like: *gltf or *glb
Inder_Chauhan
Post by Inder_Chauhan »
Hello Daniel,
Greetings,
I am a regular user of cloud compare and really happy, recently I am working with UAV dataset (specifically 3D Models *.obj format).
I have to upload a 3D-Model over web platform which accepts *gltf or *glb formats, although there are few software which converts the *.obj to *.gltf. But, they are not really dependable or convenient, as they were crashing in between or exporting the model without the texture.
Please suggest or recommend something on this.
Re: Exporting the 3D-Models in Web formats like: *gltf or *glb
Hum, this is the first time I heard about this format. The specifications are not that 'simple' (see https://github.com/KhronosGroup/glTF/bl ... cification).
Maybe if we found a C++ library to ease the creation of gdb files it could be possible. And it would be good to get some more interest feedback from users (especially since CloudCompare is not a meshing tool). By the way isn't this format supported by Meshlab?
Inder_Chauhan
Hello Daniel,
Thanks for the reply.
No, Meshlab doesn't support these formats. But, yes I found this conversion in Blender.
It would be great to have this upgrade in upcoming cloud compare versions :)
Thank you.
Inder_Chauhan
Hello Daniel,
Thank you.
mesher
Post by mesher »
You can also use the online GLTF/GLB 2.0 converter at http://modelconverter.com to convert from Wavefront OBJ to GLTF. Quick and pretty easy to use and handle large OBJ files.
