[SOLVED] CSF PLUGIN Top to bottom projection
PablerasBCN
Re: [SOLVED] CSF PLUGIN Top to bottom projection
Post by PablerasBCN »
daniel wrote: Mon Jan 01, 2024 5:59 pm This is now available in the latest 2.13.beta release!
Hello Daniel,
Can you please specify what feature was added? I downloaded the Jan18 beta and in the interface of the CSF plugin I can´t find variations neither in the command line Wiki.
cheers!
I was just reacting to 'Headless' comment: the 'command file' mechanism and the SELECT_ENTITIES options are now available (normally ;)
PablerasBCN
PablerasBCN wrote: Fri Jan 19, 2024 4:30 pm
Hello Daniel,
cheers!
OK! all clear now!
