Cross Section
Revision as of 21:10, 31 March 2022 by Daniel (talk | contribs)
Additionally, this tool can:
Editing the clipping box
Interactively
Numerically
Visualization
Extract a single slice
Extract a single envelope
Additional options are:
Extracted envelope (close-up with the slice cloud)
Extract a single contour
Extracted contours
Extract several slices, envelopes or contours
Other parameters are:
Multiple slices (left) and envelopes (right) extraction
Reset the clipping box
Close the tool
