Rasterize
Revision as of 13:41, 19 February 2022 by Daniel (talk | contribs) (→Grid position)
Input cloud
Generating a raster grid
'Rasterize' tool dialog
    • minimum height of all points falling in this cell
    • average height of all points falling in this cell
    • maximum height of all points falling in this cell
Empty cells
  • interpolate (see below)
Interpolating empty cells
Interpolation principle
Grid position
Grid extents setup dialog
Warning: the Rasterize tool uses the 'pixel-is-point' convention (the grid min corner coordinates correspond to the lower left grid cell center).
Interpolate scalar fields
Resample input cloud
Export
Cloud
Raster
ASCII matrix
Contour plot generation
The user must specify:
Since version 2.6.2
Hillshade
  • click on generate
