Display modes
Revision as of 12:47, 20 February 2019 by UnivSilesia (talk | contribs)
Main display modes
Orthographic view
Perspective view
Object-centered
Viewer-based
Fullscreen
CloudCompare has two different "fullscreen" mode:
  • either a standard fullscreen application mode (shortcut: F9)
  • or an 3D view exclusive fullscreen" mode (shortut: F11)
In exclusive fullscreen mode, only the active 3D view is made fullscreen (and will stay on top). This mode can be left by pressing on F11 again, or using the 'Leave fullscreen mode' icon that appears when the mouse hovers the upper-left part of the screen.
These options are also available via the 'Display' menu.
Bubble-view (polar)
To enable this mode:
  • highlight the sensor entity in the DB tree and click on the 'Apply' button in its properties (Viewport section)
  • or press the B shortcut if a sensor or an entity associated to a sensor object is highlighted
Stereo mode
Anaglyph
Please note that:
NVidia 3D Vision
  • by pressing the F11 key
  • by clicking on the 'Leave fullscreen mode' icon that appears when the mouse hovers the upper-left part of the screen
Oculus Rift
