Virtual broom (plugin)
Revision as of 12:23, 22 October 2017 by Daniel (talk | contribs)
Usage
Position the broom
Setup the broom dimensions
Moving the broom
Manual mode
Automated mode
Undo
Delete the points
Broom stuck
When the plugin loses the 'track' of the broom and can't stick the broom to the surface anymore (for instance when it is hangs an empty area and there's not enough points 'inside' the yellow part - or when there's too much noise), the broom will get stuck and the plugin will display a warning message (in the bottom left part). In this case, you can try to move the plugin back to 'safety', but it is generally more simple to hit the 'Undo' button once or twice.
