Virtual broom (plugin)
Revision as of 11:58, 22 October 2017 by Daniel (talk | contribs)
Usage
Position the broom
Setup the broom dimensions
  • thickness: the thickness of the broom. This is mainly used by the plugin to stick to the surface. In the default mode (cleaning), the points falling inside the broom won't be deleted. Therefore it is good to make the broom as thin as possible. However, especially for noisy or curved surfaces, the plugin won't be able to stick the broom to the surface correctly if the broom is too thin...
Moving the broom
Once correctly setup, the broom can be displaced over the surface in two different modes:
  • manual: by default, the user is supposed to manually displace the broom. Left click on the broom, keep the mouse button pressed, and then move the broom. The broom should stick to the surface, and the points falling inside the selection volume will be colored in red by default. Now all you need is time, as with a real broom ;)
  • automated: for simple surfaces such as roads, it is possible to automate the process by drawing a rectangle over the surface in which the broom will be automatically 'swept'. Look at the surface from above, change the zoom so as to see the whole area to clean, and click on the automate button. The plugin will ask you to pick two corners of the (rectangular) area to be cleaned. Actually these are two corners on the same side of the rectangle. Then you'll be able to change the width of the rectangle interactively by moving the mouse, and you can fix it by clicking a last time on the left mouse button. Once defined, the plugin will automatically sweep the broom inside the defined area.
[File:QBroom_automate.jpg|center]
