Compilation
Revision as of 21:28, 22 July 2016 by Daniel (talk | contribs)
Compilation with CMake
Prerequisites
Generating the project
    2. qCork (see below)
    4. qEDL
    5. qHPR
    6. qKinect (see below)
    8. qPCV
    9. qPoissonRecon (see below)
    11. qSRA
    12. qSSAO
    1. On Visual C++ (Windows):
[Optional] Setup for the qPoissonRecon plugin
The version of the Poisson Surface Reconstruction library (M. Kazhdan et al.) used by the is [1]. It is declared as a submodule of CC's repository. You have to explicitly synchronize it (see [2]).
Then simply check the INSTALL_QPOISSON_RECON_PLUGIN option in CMake.
Not ready yet.
  • edit the dl_dxf.cpp file
  1. MPIR 2.6.0
Generate the project files
Compiling the project
Appendix
Common issues
        //#include <QElapsedTimer>
        #include <QTime>
        typedef QTime QElapsedTimer;
  2. to compile with Visual 2010 you must then apply the following patch: [3] (this solves a bug from the MSVC 2010 compiler that prevents Qt from running correctly in release mode)
    4. And follow this guide
