Display modes
Main display modes
Perspective view
Bubble-view (polar)
To enable this mode:
To leave this mode the user must click on the
icon in the top left corner of the 3D view.
Stereo mode
Anaglyph
Please note that:
NVidia 3D Vision
- by pressing the F11 key
- by clicking on the 'Leave fullscreen mode' icon that appears when the icon hovers the upper-left part of the screen
Oculus Rift
