Rasterize
Revision as of 11:52, 22 April 2016 by Daniel (talk | contribs)
Input cloud
Generating a raster grid
'Rasterize' tool dialog
    • minimum height of all points falling in this cell
    • average height of all points falling in this cell
    • maximum height of all points falling in this cell
Empty cells
  • interpolate (see below)
Interpolating empty cells
Interpolation principle
Grid position
Grid extents setup dialog
Interpolate scalar fields
Resample input cloud
Export
Cloud
Raster
ASCII matrix
Contour plot generation
The user must specify:
Since version 2.6.2
Hillshade
  • click on generate
