Compilation
Prerequisites
- Clone the main repository and its submodules from the main git(hub) server: https://github.com/cloudcompare/trunk
- syntax: git clone --recursive https://github.com/cloudcompare/trunk.git
- Install CMake (2.8 or newer)
- Install all necessary dependencies:
- [WINDOWS] Qt (version 5 WITH OPENGL preferably but the version 4.8 is still supported)
- [LINUX/MAC OS X] qt-sdk, opengl
Generating the project
- Launch CMake GUI ('cmake-qt-gui' on linux)
- (for more convenience, you should check the "Grouped" check-box)
- make the Where is the source code field point to your local repository (for instance C:\trunk_CC).
- make the Where to build the binaries field point to ... almost anywhere you want (apart from the same folder as above!). For instance: C:\trunk_CC\build.
- click on the "Configure" button
- select your generator [already tested: Visual 2008 (32/64 bits), Visual 2010 Express (32/64 bits - see appendix), Visual 2012 Express (64 bits/Qt 5), Code::Blocks (Linux & Windows 32 bits), gcc (Linux 32/64 bits, Mac OS X)]
- Wait for CMake configuration/tests to finish...
- ...and you should see something like this:
- if you expand the "OPTION" group, you'll be able to set some general options:
- OPTION_BUILD_CC_VIEWER: whether to build or not the ccViewer side project (activated by default)
- OPTION_EXPORT_TARGETS: not documented
- OPTION_MP_BUILD: for MSVC only (mutli-process build --> much faster, but takes almost all available CPU)
- OPTION_SUPPORT_3D_CONNEXION_DEVICES: for 3D mouses handling
- OPTION_SUPPORT_MAC_PDMS_FORMAT: to activate support for PDMS .mac scripts (CAD)
- OPTION_USE_DXFLIB: to activate support for DXF files in CloudCompare/ccViewer with dxflib - see below
- OPTION_USE_FBX_SDK: to activate support for FBX files in CloudCompare/ccViewer with the official FBX SDK - see below
- OPTION_USE_GDAL: to activate support for a lot of raster files in CloudCompare/ccViewer with GDAL libray - see below
- OPTION_USE_LIBE57: to activate support for E57 files in CloudCompare/ccViewer with libE57 - see below
- OPTION_USE_LIBLAS: to activate support for LAS files in CloudCompare/ccViewer with libLAS - see below
- OPTION_USE_VISUAL_LEAK_DETECTOR: to use the Visual Leak Detector library for MSVC (http://vld.codeplex.com/)
- OPTION_USE_XIOT: to activate support for X3D files in qCC (and ccViewer) with XIOT - see below
- if you expand the "INSTALL" group, you'll be able to select which [plugin(s)|Plugins] you want to compile (by default, none are selected)
- eventually, the "CMAKE" group contains a CMAKE_INSTALL_PREFIX which is where CloudCompare and ccViewer will be installed (when you compile the INSTALL project)
- On Linux, default install dir is /usr/local (be sure to have administrative rights if you want to install CloudCompare there: once configured, you can call 'sudo make install' from the sources directory)
- On Windows Seven, you may not have the right to 'install' files in the default "Program Files" folder
- LibLAS (last tested version: 1.8 on Windows)
- and optionally laszip for LAZ files support (last tested version: 2.2.0 on Windows) --> prefer the static version (
BUILD_STATICin LASzip CMake configuration) and mind theWITH_STATIC_LASZIPoption in libLAS CMake configuration! (only appears in 'Advanced' mode) - Boost multi-thread static libraries
- make the BOOST_ROOT environment variable point to your Boost installation before launching CMake in order for the automatic 'find_package' script to work properly
- otherwise refer to LibLAS documentation for more directions
- LIBLAS_INCLUDE_DIR: LibLAS include directory (pretty straightforward ;)
- LIBLAS_RELEASE_LIBRARY_FILE: main LibLAS release library (the .lib or .a file itself!)
- [Windows] LIBLAS_SHARED_LIBRARY_FILE: full path to the liblas.dll file
- Boost multi-thread static libraries (same as libLAS)
- Xerces-C++ multi-thread static libraries
- On Visual C++ (Windows):
- select the 'Static Debug' or 'Static Release' configurations
- you'll have to manually modify the XercesLib project options so that the 'C/C++ > Code Generation > Runtime Library' are of DLL type in both release and debug modes (i.e. /MD in release or /MDd in debug)
- for 64 bits version be sure to select the right platform (x64 instead of Win32). If you use Visual Studio Express 2010, be sure also that the 'toolset' (in the project properties) is set to something like Windows7.1SDK
- only the XercesLib project neet to be compiled
- eventually, CMake will look for the resulting files in '/include' (instead of /src) and /lib (without the Release or Debug subfolders). By default the visual project will put them in /Build/WinXX/VCXX/StaticXXX. Therefore you should create a custom folder with the right organization and copy the files there.
- LibE57 (last tested version: 1.1.312 on Windows)
- WARNING: with Visual Studio (at least), you'll need the libraries compiled with /MD (=DLL Multithreaded) in release mode and /MDd in debug mode. You may have to replace all '/MT' by '/MD' in the main libE57 root CMake file (or in 'cmake/c_flag_overrides.cmake' and 'cmake/cxx_flag_overrides.cmake' if there's no "/MT" in it)
- If you found
set(Boost_USE_STATIC_RUNTIME ON)in the CMake file, comment it - the version 1.1.312 of libE57 has a small glitch that must be manually patched:
- open E57FoundationImpl.cpp and browse to the CheckedFile::operator<<(float f) method (line 4670)
- set the output precision to 8 instead of 7! (otherwise the interal checks for precision loss may fail and libE57 will throw an exception)
- OpenKinect / libfreenect (last tested version: v0.5.0 Saturn, compiled on Windows 7 32 & 64 bits - you'll need libusb)
- LIBFREENECT_INCLUDE_DIR: libfreenect include directory (pretty straightforward ;)
- LIBFREENECT_LIBRARY_FILE: main libfreenect library (the freenect.lib or libfreenect.a file itself!)
- [Windows] LIBFREENECT_SHARED_LIBRARY_FILE: full path to the freenect.dll file
Not ready yet.
- PCL (last tested version: 1.7 on Windows and 1.6 on Linux)
- Ribbonsoft's dxflib v3.3.4 or newer (http://www.ribbonsoft.com/en/dxflib-downloads - last tested version: v3.3.4 on Windows)
- edit the dl_dxf.cpp file
- browse to method DL_Dxf::writeStyle
- un-comment all commented lines (but the "dw.dxfHex(330, 0)" call) at the beginning and end of the method (i.e. lines 4130 to 4134, lines 4136 to 4139, and line 4181)
- The official Autodesk's FBX SDK (use google for this - last tested version: 2014.2 Windows)
- FBX_SDK_INCLUDE_DIR: FBX SDK include directory (pretty straightforward ;)
- FBX_SDK_LIBRARY_FILE: main FBX SDK library (e.g. libfbxsdk-md.lib)
- FBX_SDK_LIBRARY_FILE_DEBUG: main FBX SDK library for debug mode (if any)
- A compiled version of the GDAL library (http://www.gdal.org/ - last tested version: 1.10 on Windows)
- GDAL_INCLUDE_DIR: GDAL include directory (pretty straightforward ;)
- GFAL_LIBRARY: the static library (e.g. gdal_i.lib)
- MPIR 2.6.0
- the forked version of the Cork library for CC: https://github.com/cloudcompare/cork
- on Windows see the VS2010, VS2012 and VS2013 projects shipped with this fork
- for VS2010 and VS2012 you'll have to edti the "wincork" project and update the include path for MPIR (for all configurations/platforms)
- for VS2013 just edit the 'mpir' property sheet (in the Properties manager) and update the MPIR macro (in the 'User macros' tab)
- CORK_INCLUDE_DIR and MPIR_INCLUDE_DIR: both libraries include directories (pretty straightforward ;)
- CORK_RELEASE_LIBRARY_FILE and MPIR_RELEASE_LIBRARY_FILE: both main library files
- and optionally CORK_DEBUG_LIBRARY_FILE and MPIR_DEBUG_LIBRARY_FILE: both main library files (for debug mode)
Generate the project files
Compiling the project
- 'build all' should do all the compilation work (in the right order) but the binaries and libraries will be generated (by default) among all the other compilation files, in a somewhat complicated folder tree structure.
- 'install' should export all these files to the CMAKE_INSTALL_PREFIX folder, placing everything where it should be (and almost exactly as the official binary build)
Appendix
Common issues
- either set the LD_LIBRARY_PATH variable so that it points to the qCC and ccViewer installation folders (export LD_LIBRARY_PATH=...).
- or call 'sudo /sbin/ldconfig -v' once as suggested here
//#include <QElapsedTimer>
#include <QTime>
typedef QTime QElapsedTimer;
- if only Visual 2010 Express is installed, Cmake will require you to install Microsoft Windows SDK 7.1
- to compile with Visual 2010 you must then apply the following patch: [1] (this solves a bug from the MSVC 2010 compiler that prevents Qt from running correctly in release mode)
- you'll also have to compile Qt 4.8 yourself, as Nokia never provided the corresponding binaries:
- download and decompress the Qt sources
- start the Microsoft Windows SDK 7.1 command line mode with the dedicated shortcut (you'll have to add "/Release" at the end of the shortcut - edit the shortcut properties for that). Something like: << C:\Windows\System32\cmd.exe /E:ON /V:ON /T:0E /K "C:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\SetEnv.cmd" /Release >>
- if you don't have perl installed, just delete the "bin/syncqt.bat" file
- And follow this guide
Otherwise use Visual 2012 with Qt 5 64 bits ;)
