Compilation
Revision as of 21:36, 5 April 2016 by Daniel (talk | contribs)
Compilation with CMake
For compilation instructions for the latest version (2.7 and later), please refer to the https://github.com/cloudcompare/trunk/blob/master/BUILD.md.
Prerequisites
Generating the project
    2. qCork (see below)
    4. qEDL
    5. qHPR
    6. qKinect (see below)
    8. qPCV
    9. qPoissonRecon
    11. qSRA
    12. qSSAO
    1. On Visual C++ (Windows):
Not ready yet.
  • edit the dl_dxf.cpp file
  1. MPIR 2.6.0
Generate the project files
Compiling the project
Appendix
Common issues
        //#include <QElapsedTimer>
        #include <QTime>
        typedef QTime QElapsedTimer;
  2. to compile with Visual 2010 you must then apply the following patch: [1] (this solves a bug from the MSVC 2010 compiler that prevents Qt from running correctly in release mode)
    4. And follow this guide
