Rasterize
Revision as of 20:47, 6 October 2015 by Daniel (talk | contribs) (→Contour plot generation)
Input cloud
Generating a raster grid
'Rasterize' tool dialog
    • minimum height of all points falling in this cell
    • average height of all points falling in this cell
    • maximum height of all points falling in this cell
  • since version 2.6.2 the user can choose the 'active layer' that will be projected. The default layer is 'height grid values' (i.e. the coordinate of the points along the projection dimension) but it can now be any scalar field associated to the selected cloud
Once the base parameters are properly set, the user must click on the 'Update grid' button to make CloudCompare actually computed the grid and display it.
Empty cells
If no points fall inside a given cell, this cell will be considered as 'empty'. Empty cells are not visible when displayed by CloudCompare in the 3D view. They generally have a dedicated 'NaN' or 'empty' value when exported to a raster file (depending on the format).
It is possible to tell CloudCompare to fill those cells in various ways:
  • interpolate (see below)
Interpolating empty cells
The 'interpolate' option consists in a linear interpolation with the nearest non-empty neighboring cells. This can give very good results in the presence of small holes. However it can be less realistic on big holes. The biggest limitation is that it doesn't work outside the convex hull of the non-empty cells. Therefore a custom value must be specified (in the field below the 'Fill with' drop-down list) to fill these areas (if any).
Interpolation principle
Grid position
Grid extents setup dialog
Interpolate scalar fields
Resample input cloud
This option tells CloudCompare to keep in each grid cell the point which is the closest to the cell center (in 2D) instead of generating of using the cell center itself. This way it is possible to subsample the cloud in a semi-gridded pattern. If the grid is to be exported as a cloud, all the input cloud features (colors, normals, etc.) can be properly exported as well.
Export
Cloud
Raster
ASCII matrix
The user must specify:
Since version 2.6.2
