CloudCompare 3D entities
Public Types | Public Member Functions | Static Public Member Functions | Protected Attributes | List of all members
ccMaterial Class Reference
Mesh (triangle) material. More...
#include <ccMaterial.h>
Inheritance diagram for ccMaterial:
Inheritance graph
Collaboration diagram for ccMaterial:
Public Types
using CShared = QSharedPointer< const ccMaterial >
 Const + Shared type.
using Shared = QSharedPointer< ccMaterial >
 Shared type.
 ccMaterial (const QString &name=QString("default"))
 Default constructor.
 ccMaterial (const ccMaterial &mtl)
 Copy constructor.
 ~ccMaterial ()
 Destructor.
const QString & getName () const
 Returns the material name.
const QString & getTextureFilename () const
 Returns the texture filename (if any)
void setName (const QString &name)
 Sets the material name.
void setDiffuse (const ccColor::Rgbaf &color)
 Sets diffuse color (both front and back)
void setDiffuseFront (const ccColor::Rgbaf &color)
 Sets diffuse color (front)
void setDiffuseBack (const ccColor::Rgbaf &color)
 Sets diffuse color (back)
const ccColor::Rgbaf & getDiffuseFront () const
 Returns front diffuse color.
const ccColor::Rgbaf & getDiffuseBack () const
 Returns back diffuse color.
void setAmbient (const ccColor::Rgbaf &color)
 Sets ambient color.
const ccColor::Rgbaf & getAmbient () const
 Returns ambient color.
void setSpecular (const ccColor::Rgbaf &color)
 Sets specular color.
const ccColor::Rgbaf & getSpecular () const
 Returns specular color.
void setEmission (const ccColor::Rgbaf &color)
 Sets emission color.
const ccColor::Rgbaf & getEmission () const
 Returns emission color.
void setShininess (float val)
 Sets shininess (both front - 100% - and back - 80%)
void setShininessFront (float val)
 Sets shininess (front)
void setShininessBack (float val)
 Sets shininess (back)
float getShininessFront () const
 Returns front shininess.
float getShininessBack () const
 Returns back shininess.
void setTransparency (float val)
 Sets transparency (all colors)
void applyGL (const QOpenGLContext *context, bool lightEnabled, bool skipDiffuse) const
 Apply parameters (OpenGL)
bool hasTexture () const
 Returns whether the material has an associated texture or not.
void setTexture (QImage image, QString absoluteFilename=QString(), bool mirrorImage=true)
 Sets texture. More...
bool loadAndSetTexture (const QString &absoluteFilename)
 Loads texture from file (and set it if successful) More...
const QImage getTexture () const
 Returns the texture (if any)
GLuint getTextureID () const
 Returns the texture ID (if any)
void releaseTexture ()
 Release the texture. More...
bool compare (const ccMaterial &mtl) const
 Compares this material with another one. More...
QString getUniqueIdentifier () const
 Returns unique identifier (UUID)
void setTextureMinMagFilters (QOpenGLTexture::Filter minificationFilter, QOpenGLTexture::Filter magnificationFilter)
 Sets the texture minification and magnification filters.
 Destructor.
static void MakeLightsNeutral (const QOpenGLContext *context)
 Helper: makes all active GL light sources neutral (i.e. 'gray') More...
static QImage GetTexture (const QString &absoluteFilename)
 Returns the texture image associated to a given name.
static void AddTexture (QImage image, const QString &absoluteFilename)
 Adds a texture to the global texture DB.
static void ReleaseTextures ()
 Release all texture objects. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
QString m_name
QString m_textureFilename
QString m_uniqueID
ccColor::Rgbaf m_diffuseFront
ccColor::Rgbaf m_diffuseBack
ccColor::Rgbaf m_ambient
ccColor::Rgbaf m_specular
ccColor::Rgbaf m_emission
float m_shininessFront
float m_shininessBack
QOpenGLTexture::Filter m_texMinificationFilter
QOpenGLTexture::Filter m_texMagnificationFilter
Member Function Documentation
◆ compare()
bool ccMaterial::compare ( const ccMaterial &  mtl) const
Returns
true if both materials are equivalent or false otherwise
◆ fromFile()
bool ccMaterial::fromFile ( QFile &  in,
short  dataVersion,
int  flags,
LoadedIDMap &  oldToNewIDMap
overridevirtual
Loads data from binary stream.
ininput file (already opened)
dataVersionfile version
Returns
success
◆ isSerializable()
bool ccMaterial::isSerializable ( ) const
inlineoverridevirtual
◆ loadAndSetTexture()
bool ccMaterial::loadAndSetTexture ( const QString &  absoluteFilename)
If the filename is not already in DB, the corresponding file will be loaded.
Returns
whether the file could be loaded (or is already in DB) or not
◆ MakeLightsNeutral()
void ccMaterial::MakeLightsNeutral ( const QOpenGLContext *  context)
static
Warning
an OpenGL context must be active!
◆ releaseTexture()
void ccMaterial::releaseTexture ( )
Warning
Make sure no more materials are using this texture!
◆ ReleaseTextures()
void ccMaterial::ReleaseTextures ( )
static
Should be called BEFORE the global shared context is destroyed.
◆ setTexture()
void ccMaterial::setTexture ( QImage  image,
QString  absoluteFilename = QString(),
bool  mirrorImage = true
Sets texture.
If no filename is provided, a random one will be generated.
◆ toFile()
bool ccMaterial::toFile ( QFile &  out) const
overridevirtual
Warning
Doesn't save the texture image!
