CloudCompare 3D entities
Public Member Functions | Static Public Attributes | Protected Member Functions | Protected Attributes | List of all members
ccCoordinateSystem Class Reference
Coordinate System (primitive) More...
#include <ccCoordinateSystem.h>
Inheritance diagram for ccCoordinateSystem:
Inheritance graph
Collaboration diagram for ccCoordinateSystem:
 ccCoordinateSystem (PointCoordinateType displayScale, PointCoordinateType axisWidth, const ccGLMatrix *transMat=nullptr, QString name=QString("CoordinateSystem"))
 Default constructor. More...
 ccCoordinateSystem (const ccGLMatrix *transMat, QString name=QString("CoordinateSystem"))
 ccCoordinateSystem (QString name=QString("CoordinateSystem"))
 Returns class ID. More...
virtual QString getTypeName () const override
virtual ccGenericPrimitive * clone () const override
 Clones primitive. More...
bool axisPlanesAreShown () const
void ShowAxisPlanes (bool show)
bool axisLinesAreShown () const
void ShowAxisLines (bool show)
CCVector3 getOrigin () const
PointCoordinateType getAxisWidth () const
void setAxisWidth (PointCoordinateType size)
PointCoordinateType getDisplayScale () const
void setDisplayScale (PointCoordinateType size)
CCVector3 getXYPlaneNormal () const
CCVector3 getYZPlaneNormal () const
CCVector3 getZXPlaneNormal () const
virtual ccGenericPrimitive * clone () const =0
const ccGenericPrimitive & operator+= (const ccGenericPrimitive &prim)
 Add operator. More...
virtual ccGLMatrix & getTransformation ()
virtual const ccGLMatrix & getTransformation () const
 ~ccMesh () override
 Default destructor.
 Clones this entity. More...
void refreshBB () override
 Returns max capacity. More...
void invertNormals ()
void flipTriangles ()
 Flips the triangle. More...
bool reserve (size_t n)
bool resize (size_t n)
void shrinkToFit ()
 Removes unused capacity.
void clearTriNormals ()
 Removes per-triangle normals.
 Invert per-triangle normals.
 Computes normals. More...
 Laplacian smoothing. More...
 Swaps two triangles. More...
 Merges duplicated vertices.
 Destructor.
virtual void refreshBB ()=0
 Enables polygon stippling.
 Samples points on a mesh.
 Copy constructor. More...
bool isShifted () const
template<typename T >
 Copy constructor.
 ~ccHObject () override
 Default destructor.
bool isGroup () const
 Adds a child. More...
void detachAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns selection behavior.
 Copy constructor.
 Returns object name. More...
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Destructor.
 ccDrawableObject ()
 Copy constructor.
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
 Applies a display state.
static constexpr PointCoordinateType DEFAULT_DISPLAY_SCALE = 1.0
 Default Display scale.
static constexpr float MIN_DISPLAY_SCALE_F = 0.001f
 Minimum Display scale.
static constexpr PointCoordinateType AXIS_DEFAULT_WIDTH = 4.0
 Default Axis line width.
static constexpr float MIN_AXIS_WIDTH_F = 1.0f
 Minimum Axis line width.
static constexpr float MAX_AXIS_WIDTH_F = 16.0f
 Maximum Axis line width.
 Save own object data. More...
virtual bool buildUp () override
 Builds primitive. More...
ccPlane * createXYplane (const ccGLMatrix *transMat=nullptr) const
ccPlane * createYZplane (const ccGLMatrix *transMat=nullptr) const
ccPlane * createZXplane (const ccGLMatrix *transMat=nullptr) const
virtual bool buildUp ()=0
ccGenericPrimitive * finishCloneJob (ccGenericPrimitive *primitive) const
ccPointCloud * vertices ()
 Returns vertices.
 Serialization helper (output)
 Serialization helper (input)
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
PointCoordinateType m_DisplayScale
 CoordinateSystem options.
PointCoordinateType m_width
bool m_showAxisPlanes
bool m_showAxisLines
ccGLMatrix m_transformation
unsigned m_drawPrecision
 Per-triangle normals.
 Texture coordinates.
ccMaterialSet * m_materials
 Materials.
unsigned m_globalIterator
ccBBox m_bBox
 Bounding-box.
bool m_triNormsShown
bool m_materialsShown
bool m_showWired
 Wireframe display mode.
bool m_stippling
 Polygon stippling state.
CCVector3d m_globalShift
double m_globalScale
ccHObject * m_parent
 Parent.
Container m_children
 Children.
 Selection behavior.
 Dependencies map. More...
ccGLMatrix m_glTransHistory
bool m_isDeleting
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
ccColor::Rgba m_tempColor
 Temporary (unique) color.
bool m_colorIsOverridden
bool m_glTransEnabled
bool m_showNameIn3D
CCVector3d m_nameIn3DPos
bool m_nameIn3DPosIsValid
ccClipPlaneSet m_clipPlanes
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Shared pointer.
 Static factory. More...
 Sets the unique ID generator.
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
Coordinate System primitive
◆ ccCoordinateSystem() [1/3]
ccCoordinateSystem::ccCoordinateSystem ( PointCoordinateType  displayScale,
const ccGLMatrix *  transMat = nullptr,
QString  name = QString("CoordinateSystem")
Coordinate System is essentially just a way to visualize a transform matrix.
displayScaleglobal scale/size
axisWidthaxes width
namename
◆ ccCoordinateSystem() [2/3]
ccCoordinateSystem::ccCoordinateSystem ( const ccGLMatrix *  transMat,
namename
◆ ccCoordinateSystem() [3/3]
ccCoordinateSystem::ccCoordinateSystem ( QString  name = QString("CoordinateSystem"))
Simplified constructor.
For ccHObject factory only!
Member Function Documentation
◆ buildUp()
bool ccCoordinateSystem::buildUp ( )
overrideprotectedvirtual
Builds primitive.
Returns
success
Implements ccGenericPrimitive.
◆ clone()
ccGenericPrimitive * ccCoordinateSystem::clone ( ) const
overridevirtual
Clones primitive.
◆ drawMeOnly()
void ccCoordinateSystem::drawMeOnly ( CC_DRAW_CONTEXT &  context)
Reimplemented from ccHObject.
◆ fromFile_MeOnly()
bool ccCoordinateSystem::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags,
LoadedIDMap &  oldToNewIDMap
Loads own object data.
ininput file
dataVersionfile version
◆ getClassID()
virtual CC_CLASS_ENUM ccCoordinateSystem::getClassID ( ) const
inlineoverridevirtual
Returns class ID.
Implements ccObject.
◆ getTypeName()
virtual QString ccCoordinateSystem::getTypeName ( ) const
◆ toFile_MeOnly()
bool ccCoordinateSystem::toFile_MeOnly ( QFile &  out) const
