CCCoreLib 31 May 2022
CloudCompare Core algorithms
A simple mesh structure, with index-based vertex access. More...
#include <SimpleMesh.h>
Public Member Functions | |
SimpleMesh (GenericIndexedCloud *_theVertices, bool linkVerticesWithMesh=false) | |
SimpleMesh Constructor. More... | |
~SimpleMesh () override | |
SimpleMesh destructor. | |
void | forEach (genericTriangleAction action) override |
Fast iteration mechanism. More... | |
void | placeIteratorAtBeginning () override |
Places the mesh iterator at the beginning. More... | |
GenericTriangle * | _getNextTriangle () override |
Returns the next triangle (relatively to the global iterator position) More... | |
GenericTriangle * | _getTriangle (unsigned triangleIndex) override |
Returns the ith triangle. More... | |
VerticesIndexes * | getNextTriangleVertIndexes () override |
Returns the indexes of the vertices of the next triangle (relatively to the global iterator position) More... | |
VerticesIndexes * | getTriangleVertIndexes (unsigned triangleIndex) override |
Returns the indexes of the vertices of a given triangle. More... | |
unsigned | size () const override |
Returns the number of triangles. More... | |
void | getBoundingBox (CCVector3 &bbMin, CCVector3 &bbMax) override |
Returns the mesh bounding-box. More... | |
void | getTriangleVertices (unsigned triangleIndex, CCVector3 &A, CCVector3 &B, CCVector3 &C) const override |
Returns the vertices of a given triangle. More... | |
unsigned | capacity () const |
Returns the mesh capacity. | |
const GenericIndexedCloud * | vertices () const |
Returns the vertices. | |
void | clear () |
Clears the mesh. | |
virtual void | addTriangle (unsigned i1, unsigned i2, unsigned i3) |
Adds a triangle to the mesh. More... | |
virtual bool | reserve (unsigned n) |
Reserves the memory to store the triangles (as 3 indexes each) More... | |
virtual bool | resize (unsigned n) |
Resizes the mesh database. More... | |
bool | normalsAvailable () const override |
Returns whether normals are available. More... | |
bool | interpolateNormals (unsigned triIndex, const CCVector3 &P, CCVector3 &N) override |
Interpolates normal(s) inside a given triangle. More... | |
~GenericIndexedMesh () override=default | |
Default destructor. | |
virtual GenericTriangle * | _getTriangle (unsigned triangleIndex)=0 |
virtual VerticesIndexes * | getTriangleVertIndexes (unsigned triangleIndex)=0 |
virtual void | getTriangleVertices (unsigned triangleIndex, CCVector3 &A, CCVector3 &B, CCVector3 &C) const =0 |
virtual VerticesIndexes * | getNextTriangleVertIndexes ()=0 |
virtual bool | normalsAvailable () const |
virtual bool | interpolateNormals (unsigned triIndex, const CCVector3 &P, CCVector3 &N) |
virtual | ~GenericMesh ()=default |
virtual unsigned | size () const =0 |
virtual void | forEach (genericTriangleAction action)=0 |
virtual void | getBoundingBox (CCVector3 &bbMin, CCVector3 &bbMax)=0 |
virtual void | placeIteratorAtBeginning ()=0 |
virtual GenericTriangle * | _getNextTriangle ()=0 |
Protected Types | |
using | TriangleIndexesContainer = std::vector< VerticesIndexes > |
A triangle vertices indexes container. | |
Protected Attributes | |
TriangleIndexesContainer | triIndexes |
The triangles indexes. | |
unsigned | globalIterator |
Iterator on the list of triangles. | |
SimpleTriangle | dummyTriangle |
Dump triangle structure to transmit temporary data. | |
GenericIndexedCloud * | theVertices |
The associated point cloud (vertices) | |
bool | verticesLinked |
Specifies if the associated cloud should be deleted when the mesh is deleted. | |
BoundingBox | m_bbox |
Bounding-box. | |
Additional Inherited Members | |
using | genericTriangleAction = std::function< void(GenericTriangle &)> |
Generic function to apply to a triangle (used by foreach) | |
Implements the GenericIndexedMesh interface. This mesh is always associated to a (index based) point cloud that stores the mesh vertexes.
SimpleMesh::SimpleMesh | ( | GenericIndexedCloud * | _theVertices, |
bool | linkVerticesWithMesh = false |
_theVertices | the point cloud containing the vertices |
linkVerticesWithMesh | specifies if the vertex cloud should be deleted when the SimpleMesh object is destructed |
overridevirtual |
Virtual method to handle the mesh global iterator. Global iterator position should be increased each time this method is called. The returned object can be temporary.
Implements CCCoreLib::GenericMesh.
overridevirtual |
Virtual method to request a triangle with a specific index. The returned object can be temporary.
triangleIndex | of the requested triangle (between 0 and the mesh size-1) |
Implements CCCoreLib::GenericIndexedMesh.
virtual |
Vertex indexes are expresesed relatively to the vertex cloud.
i1 | first vertex index |
i2 | second vertex index |
i3 | third vertex index |
overridevirtual |
Virtual method to apply a function to the whole mesh
action | function to apply (see GenericMesh::genericTriangleAction) |
Virtual method to request the mesh bounding-box limits. It is equivalent to the bounding-box of the cloud composed of the mesh vertexes.
bbMin | lower bounding-box limits (Xmin,Ymin,Zmin) |
bbMax | higher bounding-box limits (Xmax,Ymax,Zmax) |
overridevirtual |
overridevirtual |
[in] | triangleIndex | index of the triangle (between 0 and the size(mesh)-1) |
[out] | A | first vertex |
[out] | B | second vertex |
[out] | C | third vertex |
overridevirtual |
triangleIndex | index of the triangle (between 0 and size(mesh)-1) |
overridevirtual |
This method should be ideally overriden by the child class if normals are supported
[in] | triIndex | triangle index |
[in] | P | point where to interpolate (should be inside the triangle!) |
[out] | N | interpolated normal |
Reimplemented from CCCoreLib::GenericIndexedMesh.
overridevirtual |
overridevirtual |
virtual |
n | the number of triangles to reserve |
virtual |
If the new number of elements is smaller than the actual size, the overflooding elements will be deleted.
n | the new number of triangles |
inlineoverridevirtual |
Virtual method to request the mesh size
