CCCoreLib 31 May 2022
CloudCompare Core algorithms
CCCoreLib::PointCloudTpl< BaseClass, StringType > Class Template Reference
A storage-efficient point cloud structure that can also handle an unlimited number of scalar fields. More...
#include <PointCloudTpl.h>
Inheritance diagram for CCCoreLib::PointCloudTpl< BaseClass, StringType >:
Inheritance graph
Collaboration diagram for CCCoreLib::PointCloudTpl< BaseClass, StringType >:
Public Member Functions
 PointCloudTpl ()
 Default constructor.
 PointCloudTpl (StringType name, unsigned ID)
 Alternate constructor with a name and ID.
 PointCloudTpl (const PointCloudTpl &rhs)
 Copy Constructor.
virtual ~PointCloudTpl ()
 Default destructor.
PointCloudTploperator= (const PointCloudTpl &rhs)
 Copy Assignment.
void forEach (GenericCloud::genericPointAction action) override
const CCVector3getNextPoint () override
bool enableScalarField () override
bool isScalarFieldEnabled () const override
void setPointScalarValue (unsigned pointIndex, ScalarType value) override
ScalarType getPointScalarValue (unsigned pointIndex) const override
const CCVector3getPoint (unsigned index) const override
void getPoint (unsigned index, CCVector3 &P) const override
const CCVector3getPointPersistentPtr (unsigned index) const override
void addPointScalarValue (ScalarType value)
 Adds a scalar values to the active 'in' scalar field. More...
virtual bool resize (unsigned newNumberOfPoints)
 Resizes the point database. More...
virtual bool reserve (unsigned newCapacity)
 Reserves memory for the point database. More...
void reset ()
 Clears the cloud database. More...
void addPoint (const CCVector3 &P)
 Adds a 3D point to the database. More...
virtual void invalidateBoundingBox ()
 Invalidates bounding box. More...
unsigned getNumberOfScalarFields () const
 Returns the number of associated (and active) scalar fields. More...
ScalarFieldgetScalarField (int index) const
 Returns a pointer to a specific scalar field. More...
const char * getScalarFieldName (int index) const
 Returns the name of a specific scalar field. More...
int getScalarFieldIndexByName (const char *name) const
 Returns the index of a scalar field represented by its name. More...
ScalarFieldgetCurrentInScalarField () const
 Returns the scalar field currently associated to the cloud input. More...
ScalarFieldgetCurrentOutScalarField () const
 Returns the scalar field currently associated to the cloud output. More...
void setCurrentInScalarField (int index)
 Sets the INPUT scalar field. More...
int getCurrentInScalarFieldIndex ()
 Returns current INPUT scalar field index (or -1 if none)
void setCurrentOutScalarField (int index)
 Sets the OUTPUT scalar field. More...
int getCurrentOutScalarFieldIndex ()
 Returns current OUTPUT scalar field index (or -1 if none)
void setCurrentScalarField (int index)
 Sets both the INPUT & OUTPUT scalar field. More...
virtual int addScalarField (const char *uniqueName)
 Creates a new scalar field and registers it. More...
bool renameScalarField (int index, const char *newName)
 Renames a specific scalar field. More...
virtual void deleteScalarField (int index)
 Deletes a specific scalar field. More...
virtual void deleteAllScalarFields ()
 Deletes all scalar fields associated to this cloud.
unsigned capacity () const
 Returns cloud capacity (i.e. reserved size)
Protected Member Functions
virtual void swapPoints (unsigned firstIndex, unsigned secondIndex)
 Swaps two points (and their associated scalar values!)
CCVector3point (unsigned index)
 Returns non const access to a given point. More...
const CCVector3point (unsigned index) const
 Returns const access to a given point. More...
Protected Attributes
std::vector< CCVector3m_points
 3D Points database
BoundingBox m_bbox
 Bounding-box.
unsigned m_currentPointIndex
 'Iterator' on the points db
std::vector< ScalarField * > m_scalarFields
 Associated scalar fields.
int m_currentInScalarFieldIndex
 Index of current scalar field used for input.
int m_currentOutScalarFieldIndex
 Index of current scalar field used for output.
template<class BaseClass, typename StringType = const char*>
class CCCoreLib::PointCloudTpl< BaseClass, StringType >
Member Function Documentation
◆ addPoint()
template<class BaseClass , typename StringType = const char*>
void CCCoreLib::PointCloudTpl< BaseClass, StringType >::addPoint ( const CCVector3 P)
inline
To ensure the best efficiency, the database memory must have already been reserved (with PointCloud::reserve). Otherwise nothing happens.
Pa 3D point
◆ addPointScalarValue()
void CCCoreLib::PointCloudTpl< BaseClass, StringType >::addPointScalarValue ( ScalarType  value)
inline
valuea scalar value
◆ addScalarField()
virtual int CCCoreLib::PointCloudTpl< BaseClass, StringType >::addScalarField ( const char *  uniqueName)
inlinevirtual
Warnings:
  • the name must be unique (the method will fail if a SF with the same name already exists)
  • this method DOES resize the scalar field to match the current cloud size
    uniqueNamescalar field name (must be unique)
    Returns
    index of this new scalar field (or -1 if an error occurred)
◆ deleteScalarField()
virtual void CCCoreLib::PointCloudTpl< BaseClass, StringType >::deleteScalarField ( int  index)
inlinevirtual
WARNING: this operation may modify the scalar fields order (especially if the deleted SF is not the last one). However current IN & OUT scalar fields will stay up-to-date (while their index may change).
indexindex of scalar field to be deleted
◆ getCurrentInScalarField()
ScalarField * CCCoreLib::PointCloudTpl< BaseClass, StringType >::getCurrentInScalarField ( ) const
inline
See PointCloud::setPointScalarValue.
Returns
a pointer to the currently defined INPUT scalar field (or 0 if none)
◆ getCurrentOutScalarField()
ScalarField * CCCoreLib::PointCloudTpl< BaseClass, StringType >::getCurrentOutScalarField ( ) const
inline
See PointCloud::getPointScalarValue.
Returns
a pointer to the currently defined OUTPUT scalar field (or 0 if none)
◆ getNumberOfScalarFields()
unsigned CCCoreLib::PointCloudTpl< BaseClass, StringType >::getNumberOfScalarFields ( ) const
inline
Returns
the number of active scalar fields
◆ getScalarField()
ScalarField * CCCoreLib::PointCloudTpl< BaseClass, StringType >::getScalarField ( int  index) const
inline
indexa scalar field index
Returns
a pointer to a ScalarField structure, or 0 if the index is invalid.
◆ getScalarFieldIndexByName()
int CCCoreLib::PointCloudTpl< BaseClass, StringType >::getScalarFieldIndexByName ( const char *  name) const
inline
namea scalar field name
Returns
an index (-1 if the scalar field couldn't be found)
◆ getScalarFieldName()
const char * CCCoreLib::PointCloudTpl< BaseClass, StringType >::getScalarFieldName ( int  index) const
inline
Returns
a pointer to a string structure (null-terminated array of characters), or 0 if the index is invalid.
◆ invalidateBoundingBox()
virtual void CCCoreLib::PointCloudTpl< BaseClass, StringType >::invalidateBoundingBox ( )
inlinevirtual
Bounding box will be recomputed next time a request is made to 'getBoundingBox'.
◆ point() [1/2]
CCVector3 * CCCoreLib::PointCloudTpl< BaseClass, StringType >::point ( unsigned  index)
inlineprotected
WARNING: index must be valid
indexpoint index
Returns
pointer on point stored data
◆ point() [2/2]
const CCVector3 * CCCoreLib::PointCloudTpl< BaseClass, StringType >::point ( unsigned  index) const
inlineprotected
indexpoint index
Returns
◆ renameScalarField()
bool CCCoreLib::PointCloudTpl< BaseClass, StringType >::renameScalarField ( int  index,
const char *  newName
inline
Warning: name must not be already given to another SF!
indexscalar field index
newNamenew name
Returns
success
◆ reserve()
virtual bool CCCoreLib::PointCloudTpl< BaseClass, StringType >::reserve ( unsigned  newCapacity)
inlinevirtual
This method tries to reserve some memory to store points that will be inserted later (with PointCloud::addPoint). If the new number of points is smaller than the actual one, nothing happens.
newCapacitythe new capacity
Returns
true if the method succeeds, false otherwise
◆ reset()
void CCCoreLib::PointCloudTpl< BaseClass, StringType >::reset ( )
inline
Equivalent to resize(0).
◆ resize()
virtual bool CCCoreLib::PointCloudTpl< BaseClass, StringType >::resize ( unsigned  newNumberOfPoints)
inlinevirtual
The cloud database is resized with the specified size. If the new size is smaller, the overflooding points will be deleted. If its greater, the database is filled with blank points (warning, the PointCloud::addPoint method will insert points after those ones).
newNumberOfPointsthe new number of points
Returns
Reimplemented in CCCoreLib::PointCloud.
◆ setCurrentInScalarField()
void CCCoreLib::PointCloudTpl< BaseClass, StringType >::setCurrentInScalarField ( int  index)
inline
This scalar field will be used by the PointCloud::setPointScalarValue method.
indexa scalar field index (or -1 if none)
◆ setCurrentOutScalarField()
void CCCoreLib::PointCloudTpl< BaseClass, StringType >::setCurrentOutScalarField ( int  index)
inline
This scalar field will be used by the PointCloud::getPointScalarValue method.
◆ setCurrentScalarField()
void CCCoreLib::PointCloudTpl< BaseClass, StringType >::setCurrentScalarField ( int  index)
inline
This scalar field will be used by both PointCloud::getPointScalarValue and PointCloud::setPointScalarValue methods.
