Greater control in segmentation tool
andrewmcunliffe
Post by andrewmcunliffe »
Would it maybe be possible to increase control over the segmentation tools; for example, by segmenting a sphere with a specifiable radii around a user-selected point?
(My application has many overlapping scans around the same site, so I'm trying to only incorporate data from a few of the closest and most accurate scans in the final registered model).
Cheers, Andy
Re: Greater control in segmentation tool
It may be a bit 'heavy' to add such an option to the segmentation tool.
But you can do this "manually":
  • use the point "Point list picking' tool to select the center point and create a new cloud with it
  • compute the distances between the original cloud (as 'compared') and the new single point cloud (as 'reference') - use a very low octree level as the computation might be very long.
  • eventually segment the original cloud based on its distances to the single point (with "Edit > Scalar Fields > Filter by value")
andrewmcunliffe
Thanks, I'll try that solution
