I run into the need to filter point clouds by radius measurements (Radius center located at the geometric center of a cylinder for example)
I created a tool for doing this in case any one would like to use it. Free to use, I just ask that if you improve or enhance this method, please share it with everyone here. (See instructions and sample batch file in the attachment.)
Paul
Description
At times it is desirable to be able to visualize or filter a point cloud based on radial values.
This is mostly applicable when manipulating point clouds that have a circular or spherical shape.
The technique below outlines an approach that can be used to convert the standard X and Y coordinates of a point cloud into a scalar field containing radius values.
The technique involves use of the free tool, Cloud Compare, and a few manual steps as well as use of a batch file that has been prepared to do most of the heavy lifting.
The batch file contains calls to the Cloud Compare via command line. The result is a new point cloud with a radius Scalar field based on the data from the input Point Cloud
Method for Converting X and Y into Radius Scalar Fields
- Convert X Y to Radius SF.7z
- Instructions and Sample Batch File
- (928.84 KiB) Downloaded 3402 times
Re: Method for Converting X and Y into Radius Scalar Fields
Thanks for sharing!
