black mesh
PablerasBCN
black mesh
Post by PablerasBCN »
In alpha version, when meshing a cloud it is black. In previous version it had vertex colors.
Re: black mesh
I couldn't reproduce the error. Are you sure the light is not off? (F6)
Or can you describe the process a little bit more? (does the cloud has colors or a SF initially? Which meshing method are you using?).
PablerasBCN
Re: black mesh
oh, look I'm retarded, lighting was the issue. Case Closed.
