Command Line, coloring cloud/mesh export as .ply issue
estd
Post by estd »
I'm using CC v2.11.alpha and I'm having trouble to apply the color scale to the point cloud and save it as a PLY file.
I tried different combinations absolute and relative like: Blue>Green>Yellow>Red
My source file is .xyz, it works like a charm if I use the CC normally (with relative and absolute color scale) but not in the command line.
The Z values are around zero, with little noise that the SOR filter takes out. The physical maximum values for Z are +20mm and -30mm. My goal is to have a constant scale for those limitations applied to my point cloud and save it after filtering as a colored mesh.
My current command line looks like this:
"CloudCompare -O D:\test.xyz -NO_TIMESTAMP -AUTO_SAVE ON -SET_ACTIVE_SF 0 -M_EXPORT_FMT PLY -SF_COLOR_SCALE D:\colorscale_relative.xlm -SOR 8 3 -DELAUNAY -BEST_FIT -SAVE_CLOUDS -SAVE_MESHES -CLEAR"
Attached an example of my files and a picture of what it should look like.
colorscale_issue.zip
(51.06 KiB) Downloaded 231 times
Re: Command Line, coloring cloud/mesh export as .ply issue
Your point cloud has no scalar field, it's just x y and z. So I don't see what you expect (the scalar field 0 doesn't exist, and there's no color scale applied because of that as well...)
Or did I miss something?
