Headless command line mode?
jgrn307
Post by jgrn307 »
Folks:
I'm trying to run the ICP algorithm in a fully command line mode, but I'm apparently not understanding how to do this. I am running CC command line as follows from the Docker version of CC:
CloudCompare -SILENT \
-O /data/gpfs/assoc/gears/lidarchange/scratch/wscharffenberger/ALS_TLS_UAV_registration/P406_E2/Unregistered/P406_E2_ALS.las \
-O /data/gpfs/assoc/gears/lidarchange/scratch/wscharffenberger/ALS_TLS_UAV_registration/P406_E2/Unregistered/P406_E2_TLS.las \
-ICP
But I'm getting an error:
QXcbConnection: Could not connect to display
Aborted (core dumped)
Thoughts? I'm not sure why it would be trying to connect to the display since I'm trying to run command line (there is no display on the HPC system I'm using).
Where does the output go? Does it modify the unaligned file directly?
Re: Headless command line mode?
Hum, I fear it's because the command line of CloudCompare is just a hack of the graphical version, and the executable probably requires some graphic capabilities...
FreewindUly73
Post by FreewindUly73 »
You can use cloudcompare headless by running it in xvfb, which implements the X server protocol, and to the cloudcompare executable, makes it look like there is an active X server.
xvfb can be installed with apt like so:
sudo apt-get install xvfb
and you can run your command like like so:
xvfb-run CloudCompare -SILENT \
-ICP
