Point3D to cloudIndex
Tolier
Post by Tolier »
I haven't found a function that allows me to get the index of a point in the cloud when I give it 3D coordinates
For example, with this you can obtain approximate coordinates of the point you are aiming at:
CCVector3d P;
pGLView->getClick3DPos(mouseEvent->pos().x(), mouseEvent->pos().y(), P)
But once the X, Y, Z has been stored, it is mandatory to go through the entire sizecloud and test each getpoint(index, Point) to obtain an index .
thanks
Re: Point3D to cloudIndex
In this case it would be more efficient to use the octree and find the 'nearest point' to the given coordinates (of course this point should actually be the input one). But of course computing the octree has a cost, so it has to be compared to looking through all the points. It's generally worth it if this operation is made several times.
