using -EXTRACT_VERTICES via Command line mode
tesparrow
Post by tesparrow »
Just downloaded the latest version for windows via Command line mode how do you use -EXTRACT_VERTICES as I am getting Unknown or misplaced command for '-EXTRACT_VERTICES' when loading in 2 mesh ply's as I want to convert them to clouds to use C2C_DIST etc.
Re: using -EXTRACT_VERTICES via Command line mode
Have you downloaded the latest 2.10.alpha version? (for Wndows only for now)
