I would like to remove scalar field using command line, it is possible?
I am trying to convert intesity value (scalar field 0) using -SF_ARITHMETIC command. After that I had a new scalar field, when I exported to .e57 file format the scalar field 0 is written to file, not 1. I have been trying with -SET_ACTIVE_SF command without success.
best,
Piotr
How to remove Scalar Field using command line
piotr.pioro
Re: How to remove Scalar Field using command line
Hi, I don't think it's possible for now (you can only all the SFs at once with -REMOVE_ALL_SFS)
