All public logs
Combined display of all available logs of CloudCompareWiki. You can narrow down the view by selecting a log type, the username (case-sensitive), or the affected page (also case-sensitive).
(newest | oldest) View (newer 50 | older 50) (20 | 50 | 100 | 250 | 500)- 13:25, 13 February 2024 Daniel talk contribs created page File:CcPickCenterAuto.png
- 13:25, 13 February 2024 Daniel talk contribs uploaded File:CcPickCenterAuto.png
- 13:24, 13 February 2024 Daniel talk contribs uploaded a new version of File:CcSettings.png
- 13:19, 13 February 2024 Daniel talk contribs uploaded a new version of File:QCC display toolbar.jpg
- 10:18, 4 February 2024 Daniel talk contribs created page File:Subsample dialog random percent.jpg
- 10:18, 4 February 2024 Daniel talk contribs uploaded File:Subsample dialog random percent.jpg
- 09:11, 4 February 2024 Daniel talk contribs created page File:Color scales custom label text.JPG
- 09:11, 4 February 2024 Daniel talk contribs uploaded File:Color scales custom label text.JPG
- 08:51, 4 February 2024 Daniel talk contribs created page File:Rasterize kriging.JPG
- 08:51, 4 February 2024 Daniel talk contribs uploaded File:Rasterize kriging.JPG
- 08:33, 2 December 2023 Daniel talk contribs created page Colors\From Scalar fields (Created page with "== Menu / Icon == This tool is accessible via the 'Edit > Colors > From scalar fields' menu entry. == Description == Sets the color components (RGBA or HSVA) from one or se...")
- 08:17, 2 December 2023 Daniel talk contribs created page File:Colors from sf dialog.jpg
- 08:17, 2 December 2023 Daniel talk contribs uploaded File:Colors from sf dialog.jpg
- 07:56, 2 December 2023 Daniel talk contribs created page File:Plane comparison.jpg
- 07:56, 2 December 2023 Daniel talk contribs uploaded File:Plane comparison.jpg
- 07:55, 2 December 2023 Daniel talk contribs uploaded a new version of File:Dist to primitive dialog.jpg
- 07:49, 2 December 2023 Daniel talk contribs created page Plane\Flip (Created page with "== Menu == This tool is accessible via the 'Edit > Plane > Flip' menu entry. == Description == This function simply flips the selected plane(s). The plane(s) normal will be...")
- 07:18, 2 December 2023 Daniel talk contribs created page Cloud-to-Primitive Distance (Created page with "== Menu == This tool is accessible via the 'Tools > Distances > Cloud/Primitive dist.' menu entry. == Description == Computes the mathematically correct distance between a...")
- 07:14, 2 December 2023 Daniel talk contribs created page File:Dist to primitive dialog.jpg
- 07:14, 2 December 2023 Daniel talk contribs uploaded File:Dist to primitive dialog.jpg
- 05:36, 2 December 2023 Daniel talk contribs created page Plane\Compare (Created page with "== Menu == This tool is accessible via the 'Edit > Plane > Flip' menu entry. == Description == This function simply flips the selected plane(s). The plane(s) normal will be...")
- 05:35, 2 December 2023 Daniel talk contribs created page Polyline\Sample points (Created page with "== Menu == This tool is accessible via the 'Edit > Polyline > Sample points' menu entry. == Description == Samples points along a polyline. The user can choose a fixed num...")
- 05:32, 2 December 2023 Daniel talk contribs created page Mesh\Mesh scan grids (Created page with "== Menu == This tool is accessible via the 'Edit > Mesh > Mesh scan grids' menu entry. == Description == If a cloud has 'scan grids' associated (for 'structured' clouds loa...")
- 05:31, 2 December 2023 Daniel talk contribs created page File:Mesh scan grids.jpg
- 05:31, 2 December 2023 Daniel talk contribs uploaded File:Mesh scan grids.jpg
- 05:24, 2 December 2023 Daniel talk contribs created page Mesh\Flip triangles (Created page with "== Menu == This tool is accessible via the 'Edit > Mesh > Flip triangle' menu entry. == Description == This tool changes the order of the vertices of every triangle in the...")
- 05:20, 2 December 2023 Daniel talk contribs created page Normals\Set SF(s) as normal (Created page with "== Menu == This tool is accessible via the 'Edit > Normals > Set SF(s) as normal' or the 'Edit > Scalar fields > Set SF(s) as normal' menu entries. == Description == Uses u...")
- 05:19, 2 December 2023 Daniel talk contribs created page File:Set sfs as normal.jpg
- 05:19, 2 December 2023 Daniel talk contribs uploaded File:Set sfs as normal.jpg
- 04:54, 2 December 2023 Daniel talk contribs created page File:Daw normals as lines.jpg
- 04:54, 2 December 2023 Daniel talk contribs uploaded File:Daw normals as lines.jpg
- 04:52, 2 December 2023 Daniel talk contribs created page File:Daw normals as lines gui.JPG
- 04:52, 2 December 2023 Daniel talk contribs uploaded File:Daw normals as lines gui.JPG
- 02:37, 7 September 2023 Daniel talk contribs created page 3DFin (plugin) (Created page with "3DFin is a plugin for automatic computation of tree parameters in terrestrial point clouds. It offers the users a quick, ease-of-use interface to load their forest plots and g...")
- 02:36, 7 September 2023 Daniel talk contribs created page File:3DFin CC interface.png
- 02:36, 7 September 2023 Daniel talk contribs uploaded File:3DFin CC interface.png
- 02:33, 7 September 2023 Daniel talk contribs created page Treeiso (plugin) (Created page with "TreeIso is a plugin for CloudCompare to segment trees out of a TLS point cloud. center = Documentation = Refer to the original Matlab project on [http...")
- 02:31, 7 September 2023 Daniel talk contribs created page File:Treeiso.png
- 02:31, 7 September 2023 Daniel talk contribs uploaded File:Treeiso.png
- 10:01, 2 July 2023 User account Tamu talk contribs was created by Daniel talk contribs
- 15:17, 23 February 2023 Daniel talk contribs created page Scalar fields\Split cloud (integer values) (Created page with "== Menu / Icon == This tool is accessible via the 'Edit > Scalar fields > Split cloud (integer values)' menu entry. == Description == This tool will split the cloud in as m...")
- 15:12, 23 February 2023 Daniel talk contribs created page Normals\Export normals to SF(s) (Created page with "== Menu == This tool is accessible via the 'Edit > Scalar fields > Export normals to SF(s)' menu or the 'Edit> Normals > Export normals to SF(s)' menu entries. == Descriptio...")
- 15:11, 23 February 2023 Daniel talk contribs created page File:Export normals to SFs.jpg
- 15:11, 23 February 2023 Daniel talk contribs uploaded File:Export normals to SFs.jpg
- 15:08, 23 February 2023 Daniel talk contribs created page Scalar fields\Add classification SF (Created page with "== Menu / Icon == This tool is accessible via the 'Edit > Scalar fields > Add classification SF' menu entry. == Description == Adds a new scalar field named 'Classification...")
- 14:59, 28 September 2022 Daniel talk contribs uploaded a new version of File:Cc unroll cylinder dialog.jpg
- 14:57, 28 September 2022 Daniel talk contribs created page File:Unroll angles.JPG
- 14:57, 28 September 2022 Daniel talk contribs uploaded File:Unroll angles.JPG
- 14:12, 31 March 2022 Daniel talk contribs uploaded a new version of File:Cc cross section tool repeat dialog.jpg
- 14:08, 31 March 2022 Daniel talk contribs created page File:Cc cross section tool extract real contours result.JPG
