CloudCompare 3D entities
Enumerations
CC_TYPES Namespace Reference
CloudCompare object type flags. More...
Enumerations
enum  : CC_CLASS_ENUM {
  OBJECT = 0 , HIERARCHY_OBJECT = CC_HIERARCH_BIT , POINT_CLOUD = HIERARCHY_OBJECT | CC_CLOUD_BIT , MESH = HIERARCHY_OBJECT | CC_MESH_BIT ,
  SUB_MESH = HIERARCHY_OBJECT | CC_MESH_BIT | CC_LEAF_BIT , MESH_GROUP = MESH | CC_GROUP_BIT , FACET = HIERARCHY_OBJECT | CC_FACET_BIT , POINT_OCTREE = HIERARCHY_OBJECT | CC_OCTREE_BIT | CC_LEAF_BIT ,
  POINT_KDTREE = HIERARCHY_OBJECT | CC_KDTREE_BIT | CC_LEAF_BIT , POLY_LINE = HIERARCHY_OBJECT | CC_POLYLINE_BIT , IMAGE = CC_HIERARCH_BIT | CC_IMAGE_BIT , CALIBRATED_IMAGE = IMAGE | CC_LEAF_BIT ,
  SENSOR = CC_HIERARCH_BIT | CC_SENSOR_BIT , GBL_SENSOR = SENSOR | CC_GROUND_BASED_BIT , CAMERA_SENSOR = SENSOR | CC_CAMERA_BIT , PRIMITIVE = MESH | CC_PRIMITIVE_BIT ,
  PLANE = PRIMITIVE | CC_PLANE_BIT , SPHERE = PRIMITIVE | CC_SPHERE_BIT , TORUS = PRIMITIVE | CC_TORUS_BIT , CONE = PRIMITIVE | CC_CONE_BIT ,
  OLD_CYLINDER_ID = PRIMITIVE | CC_CYLINDER_BIT , CYLINDER = PRIMITIVE | CC_CYLINDER_BIT | CC_CONE_BIT , BOX = PRIMITIVE | CC_BOX_BIT , DISH = PRIMITIVE | CC_DISH_BIT ,
  EXTRU = PRIMITIVE | CC_EXTRU_BIT , QUADRIC = PRIMITIVE | CC_QUADRIC_BIT , MATERIAL_SET = CC_MATERIAL_BIT | CC_GROUP_BIT | CC_LEAF_BIT , ARRAY = CC_ARRAY_BIT ,
  NORMALS_ARRAY = CC_ARRAY_BIT | CC_NORMAL_BIT | CC_LEAF_BIT , NORMAL_INDEXES_ARRAY = CC_ARRAY_BIT | CC_COMPRESSED_NORMAL_BIT | CC_LEAF_BIT , RGB_COLOR_ARRAY = CC_ARRAY_BIT | CC_RGB_COLOR_BIT | CC_LEAF_BIT , RGBA_COLOR_ARRAY = CC_ARRAY_BIT | CC_RGBA_COLOR_BIT | CC_LEAF_BIT ,
  TEX_COORDS_ARRAY = CC_ARRAY_BIT | CC_TEX_COORDS_BIT | CC_LEAF_BIT , LABEL_2D = HIERARCHY_OBJECT | CC_LABEL_BIT | CC_LEAF_BIT , VIEWPORT_2D_OBJECT = HIERARCHY_OBJECT | CC_VIEWPORT_BIT | CC_LEAF_BIT , VIEWPORT_2D_LABEL = VIEWPORT_2D_OBJECT | CC_LABEL_BIT ,
  CLIPPING_BOX = CC_CLIP_BOX_BIT | CC_LEAF_BIT , TRANS_BUFFER = HIERARCHY_OBJECT | CC_TRANS_BUFFER_BIT | CC_LEAF_BIT , COORDINATESYSTEM = PRIMITIVE | CC_COORDINATESYSTEM_BIT , CUSTOM_H_OBJECT = HIERARCHY_OBJECT | CC_CUSTOM_BIT ,
  CUSTOM_LEAF_OBJECT = CUSTOM_H_OBJECT | CC_LEAF_BIT
Enumeration Type Documentation
◆ anonymous enum
anonymous enum : CC_CLASS_ENUM
Enumerator
CUSTOM_H_OBJECT
Custom objects are typically defined by plugins. They can be inserted in an object hierarchy or displayed in an OpenGL context like any other ccHObject. To differentiate custom objects, use the meta-data mechanism (see ccObject::getMetaData and ccObject::setMetaData). You can also define a custom icon (see ccHObject::getIcon).
It is highly advised to use the ccCustomHObject and ccCustomLeafObject interfaces to define a custom types. Carefully read the ccCustomHObject::isDeserialized method's description and the warning below!
Warning: custom objects can't be 'fully' serialized. Don't overload the 'ccSerializableObject::toFile' method for them as this would break the deserialization mechanism! They can only be serialized as plain ccHObject instances (CC_TYPES::HIERARCHY_OBJECT). Hierarchical custom objects (CC_TYPES::CUSTOM_H_OBJECT) will be deserialized as ccCustomHObject instances. Leaf custom objects (CC_TYPES::CUSTOM_LEAF_OBJECT) will be deserialized as ccCustomLeafObject instances.
