Plane\Edit and Create
This tool is accessible via the 'Edit > Plane > Create' or 'Edit > Plane > Edit'.
The same dialog can also be displayed after right-clicking on a plane entity in the DB tree and selecting the 'Edit' option.
This dialog can be used to create or edit the parameters of a 'plane' entity.
Dialog
The dialog allows the user to set / change all the parameters of a plane entity:
  • orientation: via the geological dip/dip direction convention (since version 2.8) or via the normal vector (since version 2.9)
  • dimensions: width and height
  • center: input the X, Y, and Z coordinate of the center, or pick it directly in a 3D view
Note: planes can also be created (with less parameters) via the Primitive factory
