Grid\Mesh
This tool is accessible via the 'Edit > Grid > Mesh all scan grids' menu.
Meshes each scan grid associated to a point cloud.
This method creates one mesh per scan grid. Scan grids are very easy to mesh. They generally produce quite robust meshes.
Warning: if various scan grids are present, meshes are not merged.
Usage
Select one or several point clouds with scan grids (typically FARO or DP files). Then call this method.
CC will ask to define a 'minimum triangle angle' (useful to remove very sharp triangles created when connecting groups of points with very different depths). Default value is 1 degree.
On completion, CC will create one mesh per scan grid.
