Facets (plugin)
The qFacets plugin can:
  • automatically extract planar facets (e.g. fracture planes) from point clouds
  • export the facets to SHP files
  • classify the facets based on their orientation and their (orthogonal) distance
  • display the orientations on a stereogram/stereoplot
  • filter the facets (or the points if they have normals) based on their orientation
To cite this plugin you can refer to this article:
Dewez, T. J. B., Girardeau-Montaut, D., Allanic, C., and Rohmer, J.: FACETS : A CLOUDCOMPARE PLUGIN TO EXTRACT GEOLOGICAL PLANES FROM UNSTRUCTURED 3D POINT CLOUDS, Int. Arch. Photogramm. Remote Sens. Spatial Inf. Sci., XLI-B5, 799-804, doi:10.5194/isprs-archives-XLI-B5-799-2016, 2016.
Alternative link: Research gate.
Usage
Extract planar facets with a kd-tree
To use it, simply highlight the point cloud and click on the ExtractKD.png icon.
  • Kd-tree cells fusion parameters:
    • Max angle: maximum angle between neighbor patches (in degrees)
    • Max relative distance: maximum distance between the merged patches and the current facet center
  • Facets frame:
    • Distance criterion: this criterion is used to estimate whether a facet is still 'flat' enough after merging a new patch or not. For instance 'Max distance @ 99%' means that 99% of points have to be closer to the value specified in the field on the right (0.2 in the above example)
    • Min points per facet: facets smaller than this value will be discarded
    • Max edge length: parameter used to extract the facet (concave) contour (the smaller the closer to the points the contour should be)
To use it, simply highlight the point cloud and click on the ExtractFM.png icon.
  • the grid resolution (expressed as the subdivision level of the cloud octree as we use the octree for a faster initialization)
  • whether to re-compute the facet retro-projection error each time a patch is merged (slower but more accurate)
Export facets as a SHP file
Once a set of facets has been generated, you can export it as a shape (SHP) file. Simply select the parent container and click on the ShpFile.png icon.
  • the native orientation (i.e. Z = (0,0,1))
  • the mean facets normal
  • a custom direction (which should be set in the 3 (Nx, Ny, Nz) fields below)
  • Index
  • Center (X,Y,Z)
  • Normal (X,Y,Z)
  • retro-projection error (RMS)
  • Horiz_ext: horizontal extension
  • Vert_ext: vertical extension
  • Surf_ext: surface of the bounding rectangle (in the facet plane)
  • Surface
  • Dip direction
  • Dip
  • Family index (if any - see the Classification method below)
  • Sub-family index (if any - see the Classification method below)
Export facets as a CSV file
Simply select the parent container of the generated facets and click on the CsvFile.png icon.
Facets classification
Select the parent container of the facets and then click on the ClassifIcon.png icon.
Simply choose:
  • each family angular range (they will be regularly sampled starting from 0)
  • and the maximum orthogonal distance between facets of a sub-family (this is the orthogonal distance)
Stereogram display
The last tool of the qFacets plugin is the stereogram/stereoplot display. To use it you can either select a group of facets or cloud with normals. Then click on the Stereogram.png icon.
  • the angular step for the main sectors
  • and the angular resolution (for both the dip and dip direction dimensions)
Display options
  • the color ramp (type and number of steps) - this works just like the scalar fields color ramp (see the Color Scales Manager).
  • the small ticks frequency (for each sector)
  • and whether to display the families color around the stereogram or not
Interactive filter
  • the current selection extents (delimited by red lines) can be re-centered by clicking directly on the stereogram plot
  • when visually filtered, the facets polygon will be hidden but their contour will remain visible
