SBF
Revision as of 15:04, 21 May 2022 by Daniel (talk | contribs)
- myfile.sbf.data (binary file)
Specifications
Ascii file
[SBF]
Points=362315
SFCount=10
  • all values should be float/decimal
Binary file
This section describes the contents of the binary file (.sbf.data)
Total length: 64 bytes
0-1 SBF header flag 42 42
36-63 Reserved for later 0
Notes: with Python, the following snippet can be used to create the header:
struct.pack('>2BQH3d28x', 42, 42, no_pt, no_sf, offset_x, offset_y, offset_z)
Body
For each point (1-Np):
