Mesh Boolean (plugin)
Revision as of 22:45, 30 March 2022 by Daniel (talk | contribs) (Created page with "= Introduction File:MeshBoolean_icon.png‎ = This plugin can be used to perform Boolean operations on meshes (also called CSG = ''Constructive Solid Geometry''). It is...")
It is based on the libigl library.
  • select two meshes (meshes should be ideally closed, otherwise the output might be wrong)
  • click on the plugin icon (or the equivalent entry in the 'Plugins' menu: 'Plugins > Mesh Boolean Operations')
  • when the plugin dialog appears (see above):
    • assign each mesh to a role (A or B)
    • then select the operation to apply:
      • union: A + B
      • difference (symmetric or not): A - B
      • intersection: A n B
This plugin is very similar to the Cork plugin. It is however slower but supposedly more robust.
