Curvature
Revision as of 22:56, 19 February 2022 by Daniel (talk | contribs) (→Menu)
A dialog will appear:
Curvature output
  • the reference articles for the computation of the Mean and Gaussian curvatures are:
    • "CURVATURE OF CURVES AND SURFACES – A PARABOLIC APPROACH", Zvi Har'el (1995) - for the formulas to compute the curvature values
    • "THREE-DIMENSIONAL SURFACE CURVATURE ESTIMATION USING QUADRIC SURFACE PATCHES", I. Douros & B. Buxton, University College London (2002) - for the fitting of the 3D quadric on the points
  • the computation of the 'Normal change rate' curvature is derived from the PCL library implementation (it's equal to the smallest eigenvalue divided by the sum of the 3 eigenvalues of the local cloud covariance matrix - see pcl::NormalEstimation::computePointNormal).
