Compute geometric features
Revision as of 09:28, 23 November 2020 by Daniel (talk | contribs) (→Description)
  • Roughness (equivalent to the former Roughness tool of v2.9 and below)
    • Mean curvature
    • Gaussian curvature
    • Normal change rate
    • Number of neighbors
    • Surface density
    • Volume density
  • Moment
    • 1st order moment
  • Features
    • Sum of eigenvalues
    • Omnivariance
    • Eigenentropy
    • Anisotropy
    • Planarity
    • Linearity
    • PCA 1
    • PCA 2
    • PCA 3
    • Surface variation
    • Sphericity
    • Verticality
    • 1st eigenvalue
    • 2nd eigenvalue
    • 3rd eigenvalue
A dialog will appear:
Note: currently each feature is computed independently. The extraction of the local neighborhood is sadly not leveraged for all the features...
Output
