SBF
- myfile.sbf (text file with meta-data) - myfile.data.sbf (binary file)
Specifications
Ascii file
[SBF]
Points=362315
SFCount=10
SF10=name of scalar field{, p=precision, s=shift value}
Note that the 'p' and 's' options for the scalar fields are optional.
Binary file
Header
Total length: 64 bytes
Body
For each point (1-Np):
