M3C2 (plugin)
Revision as of 19:55, 4 July 2019 by Daniel (talk | contribs)
Precision Maps
Computing M3C2 distances
Main parameters
  • either the whole cloud
Precision maps
Advanced
Output
Save/load parameters
Computing distance
Command line
CloudCompare -O cloud1 -O cloud2 (-O core_points) -M3C2 parameters_file
