Open
Revision as of 22:55, 23 February 2019 by UnivSilesia (talk | contribs)
This tool is accessible via the 'File > Open' menu or the icon in the upper main toolbar.
Loads entities from one or several files.
File > Load dialog
Select the right file type (with the drop-down list next to the filename field). Alternatively you can let CloudCompare guess it from the file extension (use the 'All (*.*)' entry).
A file typically contains one or several entities (clouds, meshes, etc.).
  • read-only access to the files. Moreover, once the entities are loaded CloudCompare will close the file and 'forget' about it.
  • the loaded entities are automatically put in a 'group' which has the input filename as name. However this group has no link to the file.
  • alternatively, files can be opened by dragging them from the file explorer and dropping them on a 3D view.
Supported formats
