Compass (plugin)
A plane is fitted to each trace (using least squares) when it is finalized (green tick or space key), providing an estimate of the structure orientation. Unfortunately, in some situations the best-fit plane does not provide a robust estimate of structure orientation, particularly in low relief. To help avoid these issues, planes deriving from traces which are co-linear or within 10° of the average surface orientation along the trace (if point normals have been calculated). Further details on the automatic vetting process can be found at <ref>Template:Cite journal</ref>.
Exporting data
Further Reading and Citation
