Unroll
Cylindrical shape to unroll
Cylindrical shape unrolled
Unrolled cone
Cylinder
'Unroll cylinder' dialog
  • cylinder radius
  • and optionally a point on the axis (otherwise CloudCompare can try to guess it by computing the gravity center of the point cloud)
Cone
'Unroll cone' dialog
Straightened cone
