Compass (plugin)
  • Curvature - traces follow points on ridges and valleys. This can be good for fracture traces with high relief but can be slow and sensitive to noise. For better performance, use the Curvature and [Gaussian filter,http://www.cloudcompare.org/doc/wiki/index.php?title=Scalar_fields%5CGaussian_filter] tools to create a scalar field which highlights areas of high curvature, then use the Inverse Scalar Field cost function.
  • Gradient - traces follow colour boundaries such as lithological contacts. Note that this can be slow and is very sensitive to noise. For better performance, use the Gradient tool and Inverse Scalar Field cost function as described above.
Exporting data
Further Reading and Citation
