Normals\Compute
Revision as of 20:58, 4 September 2016 by Daniel (talk | contribs)
This tool is accessible via the 'Edit > Normals > Compute' menu.
Computing normals on a cloud
Local surface model
Neighborhood
Since version 2.6.2:
Orientation
Computing normals on a mesh
