Level
This tool is accessible via the 'Tools > Level' menu or the
icon in the left toolbar.
- try to pick the points as far as possible from each other to optimize the plane orientation 'accuracy'
- you can cancel the process any time by clicking on the tool icon again
- the first clicked point will be used as origin for the new coordinate system. The vector between the first and second clicked points will be the new 'X' dimension.
- this tool modifies the selected entities directly. You may want to clone or save them prior to call this tool.
