CANUPO (plugin)
Getting a working classifier
Use an existing ".prm" file
Train your own classifier
Prepare the data
Train a classifier
Apply a classifier on a cloud
Command line
Since version 2.10, the plugin can be called via the command line:
  • you'll need a trained classifier (.prm file)
  • main option:
    • -CANUPO_CLASSIFY {classifier.prm}
  • additional options:
Acknowledgments
