how to find out depressions/dips/low points
Posted: Sun Jul 14, 2024 2:29 pm
by a_u_r_09
hi
i want to detect/mark the depressions/dips/low points on grounds. please guide how to do it.
thanks
Re: how to find out depressions/dips/low points
Posted: Mon Jul 15, 2024 3:03 pm
Do you have an example cloud / screenshot maybe?
Posted: Fri Jul 19, 2024 7:35 pm
by a_u_r_09
i want to find out the dips like i encircled them. these are below the plane surface.. may be 1 feet or less than that....
i need to know.. how to find out the dips or depression areas...
Posted: Sun Jul 21, 2024 7:44 am
by a_u_r_09
daniel wrote: Mon Jul 15, 2024 3:03 pm
daniel can u plz guide me.... this is urgent
Posted: Sun Jul 21, 2024 8:38 am
Ah, that's a small screenshot ;)
Hard to know how it will work, but you could first try to extract the ground points with the 'CSF' plugin. Make sure to use the latest version of CC as this plugin was improved. And ask the plugin to export the ground mesh also. If it gives a good result, you might be able to compute the distances between the original cloud and this mesh, so as to better identify the points 'below' the ground.
By the way, it might also be interesting to inverse the Z coordinates (with 'Edit > Multiply/Scale' and using -1 for the Z dimension only). And then apply again the CSF plugin. You might get as 'non-ground' points the points you are interested in.
Hard to provide more support without the real cloud. Don't hesitate to send it to me if you can (
[email protected])
Posted: Mon Jul 22, 2024 12:13 pm
by a_u_r_09
thanks... i will try and let u know as well....
