Import normals from scalar field
mariolino
Post by mariolino »
Is it possible to implement this feature?
At present I have to export the cloud in ascii and then re-import it indicating the fields of the normal, it would be much easier if there was this command
Many thanks
Re: Import normals from scalar field
Interestingly, I just addded this feature in the latest 2.13.beta version (last Saturday!).
See https://www.cloudcompare.org/doc/wiki/i ... _as_normal
mariolino
Post by mariolino »
It works correctly, very well!!!
To set scalars as coordinates it would be nice to have the same interface like this, to be able to set three values at the same time (as possible values there should be the current coordinates , I use scalars to give the same cloud other projections).
Many Thanks
Mariolino
